Trying to get file name from string path
I have a file path, which I convert to a string.
Example: C:\Test Path 1\Location 1\Location 2\This_Is_The_File_I_Want-1234.elf
I am trying to use the Match Regular Expression Function to search for the value of the file name between the last "\" and before ".elf". I am unsure how to configure it so that it will search between those two search parameters to return the file name.
Does anyone have a better method for searching for the name of that file? It can change over time, hence wanting to dynamically search for it.
(5,236 Views)
First of all, don't convert it to a string:
Bill
CLD
(Mid-Level minion.)
(5,227 Views)
Sorry, Nevermind.
(5,226 Views)
In addition to what billko suggested, you can use the Get File Extension vi from the Advanced File Functions palette. This vi gives you the filename without extension as you require.
Paolo
(5,180 Views)
Accepted by topic author LearningLabVIEW
Yes, as mentioned.
As for the regular expression, there are tons of variations to get similar results.
Following is for educational purposes.
This returns anything* between the last "\" and before ".elf", but it does anchor .elf to the end of the string (the "$").
* Anything, including ".elf". So  "C:\Test Path 1\Location 1\Location 2\This_Is_The_.e;lfFile_I_Want-1234.elf" returns "This_Is_The_.elfFile_I_Want-1234" as the first ".elf" isn't anchored to the end.
If you'd really want to match anything between the last \ and .elf the regex get a lot more complicated.
(5,151 Views)
Here's a combination of some of the suggestions:
And, as has been mentioned, if you already have it as "path" datatype, it never needs to be converted to a string in the first place.  A full path is OS independent, but once you convert it to a string, it will be OS specific and the code will break on other platforms.
(5,139 Views)
Oops, I forgot about that part of the requirement.
Bill
CLD
(Mid-Level minion.)
(5,124 Views)
