Trying to build a numeric keypad from scratch...
I'm a student working on my final project (just passed my first CLAD exam!)
I'm trying to use a Boolean array to generate a 4-digit passcode. So far I am able to get the correct # to show up, but I want to eliminate the -1 default for no input. I'm having to run continuous because of that darned -1, which is defeating the point of enabling/diabling the alarm. Eventually I would like to concatenate the four digits and compare to a constant to arm/disarm. This VI will be added to another VI w/ NI Elvis board w/ multiple emitter-detector sets, which I have working fine. I would like to add this feature to enhance that one.
Can anyone help?
Here's what I have so far:
Message 1 of 15
(6,410 Views)
add a plus one after the search 1D array
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 15
(6,396 Views)
check that what values are you looking for? I am getting correct values except I get -1 when nothing is hit is this the problem?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 3 of 15
(6,395 Views)
Use an event structure.
Message 4 of 15
(6,387 Views)
Accepted by topic author djsunkist
This is the easiest way to do it. Create event for the buttons and use a case structure for checking the -1... Check the attached vi. This takes an input password length of 5 characters.. after that it stops...
Nitzz
(Kudos are always Welcome, Mark as a solution if it is the One;))
Message 5 of 15
(6,375 Views)
Oh, Dennis has already told this..:)
Message 6 of 15
(6,373 Views)
Wow, exactly how I need it to work!
Thank You so much!
I haven't worked w/ the event structure before this: very interesting.
Looks like I can equal the result to a string constant to remain running and not-equal to the stop button as well - Perfect!
Kudos and Thanks Again
LabView Rocks!!!
Message 7 of 15
(6,362 Views)
You may Accept it as a solution if your problem is solved so that others can also refer it when required.
Nitzz
(Kudos are always Welcome, Mark as a solution if it is the One:smileywink:)
Message 8 of 15
(6,359 Views)
you should also make the number pad a cluster like this:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 9 of 15
(6,340 Views)
Hi Harold,
That's really nice..:) Ideal way to program ....!!!
Nitzz
Message 10 of 15
(6,337 Views)
