Trouble with LabPython - unable to get it running...
Hey,
i have the same problem. Now i use the python2.7. I have added the line "PythonServer=C:\WINDOWS\system32\python27.dll" to the file Labview.ini . But after, if i tried to run "PYTHON Array Example__ogtk.vi", it shows alwayslabview_failure.gif
who can help me to solve this problem?   Thanks!
Message 12 of 14
(1,812 Views)
I also had trouble running example and the fix was to use python25.dll instead of python27.dll and use the python set server path to point to python25.dll and add this set server call in front of the python array example and now it runs
LabVIEW 2016 32 bit version
Message 13 of 14
(1,152 Views)
LabPython is pretty old. (Note last post here was almost 7years ago!!)  If it still does what you need great, but you might run into issues.  For a more modern approach you might look at -
https://forums.ni.com/t5/NI-Blog/LabVIEW-and-Python-Friends-or-Foes/ba-p/3594212
http://blog.thepythontutor.com/2017/05/scripting-python-with-labview.html
http://sine.ni.com/nips/cds/view/p/lang/en/nid/213990
Message 14 of 14
(1,149 Views)
