Trigger restarts on DAQ board
Hi.
I'm doing data acquisition with a DAQ board, the USB-6251 model.  I need something like the sample VI "Acq&Graph Voltage-Int Clk-HW Trig Restarts.vi", except I need the trigger to restart much more efficiently.  When I run that sample VI (and my own adaptation which is attached) I can only get trigger rates of about 30 Hz, and trigger that comes in within 30 ms of the previous one is just ignored.  I need it to handle trigger rates of up to 1 kHz. Does anyone have any ideas, or is there another way to go about it that will avoid this problem?
Jeremy
Message 1 of 8
(4,106 Views)
I think to get the response you want, you will have to use your Trigger signal to start generate the correct number of clock signals from a Counter.  See example 'Gen Dig Pulse Train-Finite-Retriggerable.vi'
Use Example 'Cont Acq&Graph Voltage-Ext Clk.vi' to actually do the acquisition.
For a test, set up as follows:
Set the Rate/Frequency to the same value.
Set the Number of Pulses/Samples to Read to the same value.
Set the Counter(s)/Clock Source to the same source
  1. For the Gen Dig Pulse Train-Finite-Retriggerable.vi set Counter(s) to ctr0
  2. For the Cont Acq&Graph Voltage-Ext Clk.vi set the Clock Source to Ctr0Out
Run the Cont Acq&Graph Voltage-Ext Clk.vi first and then quickly start the Gen Dig Pulse Train-Finite-Retriggerable.vi
You should see the acquired signal from whatever input you have connected.  I was able to do this without changing either example program.  Once you see it work, you can combine the two into one vi.
Message Edited by rpursley8 on 07-07-2009 04:19 PM
Randall Pursley
Message 2 of 8
(4,098 Views)
Accepted by mets501
Attached is an example combining both together with an event structure to do the actual reading of the analog channel.
Randall Pursley
Message 3 of 8
(4,087 Views)
Wow, you're a lifesaver!  Thanks so much for your help, and for actually putting it together for me.
Jeremy
Message 4 of 8
(4,080 Views)
Is there any chance you could post a .jpg of the DAQmets program?  I'm running LabView 7.1, and can't see the contents of your program.
Thank you.
Michael
Message Edited by Michael7331 on 07-08-2009 11:49 AM
Message 5 of 8
(4,060 Views)
Yep, it's all attached.  Enjoy 🙂
Message 6 of 8
(4,050 Views)
Thank you very much for the quick and helpful reply!  Have a great day!
Michael
Message 7 of 8
(4,046 Views)
Michael
Message 8 of 8
(4,045 Views)
