Trigger creation of new TDMS file
Please , I need to trigger the writing and the creation of new measurement file using a button. So if I press the button I start writing to the file and when I release it the file should be closed. And after, if I press the saving button again it starts saving to a new files.. and so on ...
Please any ideas ?  I ll be very grateful 🙂
Thank you in advance,
Tanieta.
Message 1 of 12
(4,576 Views)
Message 2 of 12
(4,547 Views)
HI @Artem.SPb,
THank you for your reply.
I've tried with Create File with Incrementing Suffix VI,  but i seems that is creating a new files on every loop iteration.  and I couldn't get rid of this problem.
Any hints ?
THankyou
Message 3 of 12
(4,539 Views)
Accepted by Tanieta
Message 4 of 12
(4,537 Views)
Hi Artem.SPb ,
Thank you very much for your quick reply 🙂
I just want to know the Vi, connected to the boolean variable.
Many many thanks,
Tanieta
Message 5 of 12
(4,529 Views)
Hi Artem.SPb ,
Many thanks again, the script works very good regarding the triggering.
However when opening the files I get the error:
***************** New logfile section *******************
TDMS: ERROR: TDS Exception in Initialize: Tds Error: TdsErrNotTdsFile(-2503):
I've checked similar problem in the forum, but didn't find a concrete solution 😕
Any help ?
Nice day 🙂
Message 7 of 12
(4,510 Views)
show your code
Message 8 of 12
(4,506 Views)
Here it is
Message 9 of 12
(4,503 Views)
Accepted by Tanieta
Message 10 of 12
(4,498 Views)
