Trigger LCR with SMU to get CV curve
I have an Agilent 4284A LCR meter, and need to acquire a CV curve. The Source is a Keithley 2410, and both are using GPIB 488.2. I have a while loop to sweep through the different voltages and on each loop we get the capacitance. I was wondering if there is anything needed to be done regarding the triggering? I am not familiar at all with this. I attach the VI I have created so far.
Also, not sure if the (second) enable output subVI from the 24xx drivers should or should not be there. They run it like that in all the drivers examples.
Thanks!
Message 1 of 1
(1,409 Views)
