Get name of Parent Class of a Child Class
Hi All
As the title states, is it possible to get the name of the parent class if I have an object of the child class?  Is there an exist VI or property I can access?
For example, if I have a ChildB.lvclass that inherits from ParentA.lvclass, I want to be able to get the name "ParentA.lvclass" from ChildB.
Mike
(4,997 Views)
Have you already installed GOOP?
You can achieve the way using "GOOPUtil_GetParentClassesHiererchy.vi"GOOP.PNG
Certified LabVIEW Developer
GCentral
(4,953 Views)
You could also make a get name method that returns an array. Force each child to implement the method, and to unconditionally call the parent method.
Why do you need this? If it's not for error reporting or debugging, there might be better solutions.
(4,927 Views)
Do you need this at run-time or at edit-time?
(4,889 Views)
Need this at run-time, preferably w/o having to install a 3rd party solution like GOOP.
However, I think I am going to work my way around it and try a different approach.
Regards
(4,858 Views)
Once again, carya, you've pulled me from the jaws of sin.  I'm now back on the path of righteousness - usinf DynoDispatch VI's for their intended purpose!
(4,521 Views)
(4,507 Views)
