Triangular voltage pulse
I'm new to Labview, and I have been struggling to get it to work. I was wondering if someone could help me in getting the pulse of the attached graph.
I'm using a Keithley Source Meter model 2400-C and an USB/GPIB Interface 82357B from Agilent technologies.
I just want to apply the voltage for sometime and then turn it off.
Any help will be highly appreciated!
(3,180 Views)
Hi efa,
            For getting a pulse as you attached,it's simple.See the attachment.But...
Just simply apply a voltage for sometime, then turn off, then apply voltage again, and repeat
You have to explain more clearly about your requirement.
Thanks as kudos only:)
(3,167 Views)
Sorry I just now saw your edited message...
(3,165 Views)
Thanks for the attachment. I meant that I want to apply that pulse for some time, let's say 1 min and that's it.
(3,164 Views)
Hi efa,
            You can achieve it using a loop.
(3,152 Views)
