Tree viewer read from json
Hi All
May I know ? ,  Is there any way to make tree view by read from json file ?
Thank you
BR
Bee
Message 1 of 9
(276 Views)
Hell weerapong,
there is no built-in function in LabVIEW.
Is the structure of the JSON- String known? Can you convert it to LabVIEW- Types via the LabVIEW-Json-VIs (or JKIs VIs)?
Greets, Dave
Message 2 of 9
(250 Views)
Here's a simple routine I made a while ago for viewing JSON file in a LabVIEW tree. Each element's tag is the full path name to the element.
Message 3 of 9
(226 Views)
nice!
once upon a time, i figured out, that firefox does have a very fine out of the box .json viewer if you open such a file in firefox browser directly
since that, i always used that one...
I guess firefox can be loaded via labview's dotrnet node ... and ... nevermind
Message 4 of 9
(194 Views)
Hi All
Thank you for your support.
That's a good start for me.
BR
Bee
Message 5 of 9
(143 Views)
Hi Jacobson
May I have your sample with LV 2019 ?
Thank you.
BR
Bee
Message 6 of 9
(127 Views)
@weerapong wrote:
Hi Jacobson
Thank you.
BR
Bee
I attached a zip of the code in 2019. I'm not used to using the new backsave feature so hopefully I did that right.
Message 7 of 9
(81 Views)
Hi Jacobson
Thank you very much.
BR
Bee
Message 8 of 9
(45 Views)
I have come across the same problem with the addition that I wanted a simple json editor as well. With the possibility of a webview browser in LabVIEW it was quite easy to use the javascript jsoneditor library.
Check out the "JSON Editor.vi" example in my WebView-Components-for-LabVIEW library. It is not released yet on VIPM, but the JSON editor has been used for a while now.
Message 9 of 9
(15 Views)
