Transmit Video from one USRP to another using LabView
I want to run NI USRP Example LabVIEW VI from the below link. But I do not have MIMO cable. So I want to know what are the main things I have to consider if I want to eliminate the MIMO cable and use just the antenas for transmit and receive?
Do I need to make any changes in the VI or not?
Please guide.
Thank you,
JK
NI USRP Example LabView VI
(4,194 Views)
Hi Joseph,
Firstly, what USRP are you using and are you trying to do any synchronization?
Can you tell me a bit more about your application? Are you specifically interesting in video transmit or are you looking for a general example for Tx/Rx with USRP or USRP RIO?
(4,130 Views)
I am using USRP 2920 but instead of USRP 2920 daughter baord we have LFTX and LFRX daughter boards, which has a carrier frequency of 0 to 30MHz. I am specifically interested in video transmission between one USRP to another USRP and I wanto to connect both USRPs with different laptops. So can you guide me how can I run the above mentioned video transmission example VI in this case.
JK
(4,042 Views)
The example you linked has different vi's for transmission and receiving, so if you want to run this with USRP's on different systems I imagine you would run the transmission vi on one system and the receiving on another.  I'm not familiar with the programming needed for MIMO so unfortunately I can't tell you what you would have to change to not use it.  I would assume that if you were not using MIMO you could start with a simpler USRP transmit or receive vi example and go from there.
Jon F.
Technical Support Engineer
(3,976 Views)
