Error -1074360293
I am using a couple of web cameras  mounted over a  plataform.  My routine  is made of 4 steps as a secuence
1. go to the initial position and find a pattern on an image which comes from the web camera #1 (continuous acquisition). the pattern can be in the image several times so I have to locate all of them and capture their positions.
2.  go to another position and take a continuous image using the camera 2 . the idea is to monitorize a motion.
3. go to a third position and find again a pattern which can appears several times  so it is esentillay the same as step 1
4. go to fourth position and take a continuous image using the camera 2 .  again the idea is to monitorize a motion.
Although the steps 1-3 and 2-4 looks simmilar, they  need to be considered as separate steps because of some conditions.
I attached a simpler version of  my program (but it includes only the vision components) which  show the 4 steps and reproduces the problem I am having. i.e. show explicitely the error message
The problem appears  in the step 3 and the error  message is:
Error -1074360293 occurred at IMAQdx Get Image.vi
Possible reason(s):
NI-IMAQdx: (Hex 0xBFF6901B) Timeout
I discovered that if I use only one camera, the problem dissapears , however, in that way I can just either find the patterns or monitorize the motion (note that both actions are not simultaneous ) because the cameras are located in differenrt positions on the plataform .
I am using a machine with:
windows 7 de 64 Bits
Intel core i7 @2.3GHz
4 Gb ram
LabVIEW professional development system 2011 SP1 version 11.0.1f2(32bit)
2 web cams logitech c170
I appreciate any suggestion to solve this problem
(3,830 Views)
Hi jmonroy,
One possible step to try is to increase the timeout of your camera in Measurement and Automation Explorer. You can go to My System>>Devices and Interfaces>>NI IMAQdx Devices>>camera name. In the acquisition attributes you can change the timeout value in ms to a higher value.
Paolo F.
(3,731 Views)
