Transferfunction as a plant process control parameter
         Below attached is a pid controller.In that I used a sub VI  of a tranferfunction for control.But there showing some errors.Can anyone plz suggest the input and output of that sub VI.Can we make it as a working one.plz help.
Thanks as kudos only:)
(3,403 Views)
Include the subvi. how do we run your code?
Be specific. What are the errors it is showing? What does your code do?
(3,393 Views)
Hope you can see the sub VI named TrFn in the blockdiagram.The VI works good when we use Transferfunction module(H(S)) in control and simulation toolkit.But Iam trying to use my own TrFn subVI.Is it possible???
Thanx
(3,390 Views)
I have searched a bit and I dont think you can.
But why do you need that? you can configure the transfer function subvi itself according to your system needs.
If there are too many feedforward/ feedback loops just create the block diagrams adding/subtrating transfer function wherever necessary.
I found these links helpful
https://decibel.ni.com/content/docs/DOC-20631
http://zone.ni.com/devzone/cda/tut/p/id/6931
this is a bit detailed, just see the pid part
http://home.hit.no/~hansha/documents/labview/training/Control%20and%20Simulation%20in%20LabVIEW/Cont...
(3,378 Views)
I just tried to use my own sub VI as a part of my study.
Thanx.
(3,371 Views)
