Transfer File using AS2 protocol
I have to transfer file over AS2 protocol using certificate and details provided by client. I had searched over and found some application whom working for transfer using AS2 like ArcESB, Goanywhere, etc. I had to transfer it using LabVIEW only. Suggestions and Solutions are awaited.
(2,631 Views)
Accepted by prs4703
Why do you have to use LabVIEW only?
Bill
CLD
(Mid-Level minion.)
(2,575 Views)
Accepted by prs4703
I would suggest you find a 3rd party tool that can do that and then run it from LabVIEW using the command line, .NET nodes, python nodes, or some other form of 3rd party tool access.
(2,571 Views)
Yes you are right. I used a third party server and implemented in labview.
(2,552 Views)
can you please tell me the 3rd partty library to use for implementing as2
(1,132 Views)
