Toggling LED in sequence frames
<LV 8.5> Hi all. This problem has elude me for a few vi's now & I just can't seem to find a solution.
I have one LED on the front panel and need to toggle it on in frame 1, off in frame 3. I have T/F constants in each frame. They control a digital ouput for a simple PWM cycle timer.
LV won't let me feed both these 2 T/F's  into one LED. I have tried using local variables but same thing. I know there is a very simple solution but I just can't get anything I can think of to work. Any help appreciated.
Walt Donovan
Labview 8.5
Meas Studio 2008
(3,072 Views)
Accepted by topic author walter-donovan
You simply have to place the locals in the frames and wire them up.
(3,067 Views)
Thanks Dennis. I was doing it backwards by attaching a single local to the LED and trying to write it with both T/F's.
It is a simple program but an important one. It controls a sump pump that has no float switch. I live in the northeast near the coast. My house thanks you as well.
wd
Labview 8.5
Meas Studio 2008
(3,053 Views)
