Toggle between waveform charts
I have 3 waveform charts showing different data but I'm trying to create a front end where I can toggle between the 3 graphs so I can see one graph at a time. I would preferable like to use a button that can toggle between the charts. Is there any way to do this or have an example of anything that does this?
Message 1 of 13
(1,853 Views)
The simplest solution would be to use a Tab Control, with each graph being in its own tab page.
Message 2 of 13
(1,833 Views)
What if I wanted the displays to be on one tab but toggle through them?
Message 3 of 13
(1,829 Views)
Use exactly one chart with three traces and expose the visibility checkbox in the legend.
(Or tie visibility to a radio button control if only exactly one trace should show)
Message 4 of 13
(1,788 Views)
Here's how that could look like:
Message 5 of 13
(1,785 Views)
I have a new requirement where the waveform chart has to display 2 graphs at the same time. So total 6 graphs 2 on each chart.
Is there anyway I can change the above VI to implement the new requirement?
Message 6 of 13
(1,673 Views)
Hi AJ,
So before you had 3 PLOTS and you wanted to show one of them.
Your "new" requirement is to manage 6 plots and make two of them visible.
In which way is this a "new" requirement? It's basically the very same requirement…
Message 7 of 13
(1,666 Views)
I'm just not sure how to change the VI above to only show 2 at a time. I have tried build array and other methods but nothing seems to work.
Any suggestions?
Message 8 of 13
(1,630 Views)
Hi AJ,
Any suggestions?
Altenbach's VI uses a FOR loop inside an event case.
  • This loop is set to 3 iterations because of 3 available plots: set the number of iterations to 6 when there are 6 plots now.
  • Inside the loop one plot is set to visible, the others to invisible: change the condition according to your requirements so you set two plots visible…
Message 9 of 13
(1,621 Views)
I'm not sure how to edit the for loop to make for this change. Everything I have tried does not seem to work.
Message 10 of 13
(1,612 Views)
