Finite digital measurement with DAQ timing
Hello. I want to make a code that measures finite digital signals using ni9423. What I was trying to make was a code that measures digital signals 10 times per second. I really want to use daq timing to measure every certain amount of time. But when I run the code, it only runs once and ends. Which part should I fix? Thank you.
(811 Views)
Just use while loop which will iterate every 100 ms - this will give 10 measurement per second:
(799 Views)
Thank you for your kind reply, but if I turn the while loop with the other loop, there is a problem of delay than 100ms. Do you happen to know how to solve this?
(794 Views)
Hi Andrey,
most of the stuff shown in your image belongs outside the loop...
(792 Views)
And no wait in the loop needed.
the samplerate and number of points to read define the (min*) loop duration.
*) min, because depending on the other stuff you put into the loop.  (but you can look at the producer-consumer architecture if things get critical)
Greetings from Germany
Henrik
LV since v3.1
(730 Views)
