To more specific class for waveform chart
Dear All
In the attached VI diagram the "To more specific class" gives an error messag:
LabVIEW:  Type mismatch: Object cannot be type casted to the specified type.
so it can not work for my waveform chart. I think I changed some properties or some thing similar for my chart that can not work with this routine because it works for new instances of waveform charts but whatever I try to find the difference between my waveform chart and a new instance of waveform chart I don't not find any difference.
 Do you have any clue?
Best regards
Afshin
Message 1 of 8
(3,753 Views)
Hi there
i don't think it is possible to cast a reference of a non - strict typedef ctl to a strict typedef ctl type.
Are you sure the ctl references are pointing to instances of the strict typedef? If not just use a "Waveform Chart" type.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 8
(3,749 Views)
Dear Chris
When I make a reference to my chart ("creat reference") and create a constant for that reference it gives "strict waveform chart" so I think it is a strict type and it works for new instances of chart when I add them on the panel.
Regards
Afshin
Message 3 of 8
(3,744 Views)
chrisger wrote:
Hi there
You can but it has to be the right type since things like the History node has to adapt if the chart is using DBLs Waveform data type etc.
In this example
1) Rihgt-click and make the strict ref constant into a control
2) ctrl-drag the waveform chart (the actuall chart used on the FP) into the control you created in step #1. The control will adapt the right type.
3) make the control a constant again.
Ben
Message 4 of 8
(3,740 Views)
Try to use the "Controls[]" and the "ClassName" property instead. See attachment.
Best regards
chris
Message 5 of 8
(3,738 Views)
Hmm, he stated that he created the class specifier constant by right clicking an instance of the original strict typedef, so the constant should match.
Am i missing something?
Best regards
chris
Message 6 of 8
(3,735 Views)
I suspect "... I think I changed some properties or some thing similar for my chart ..." from the original post.
 BTW Class names are subject to change by NI without notice. The class ID (?) is concidered safer but not totally safe.
Ben
Message Edited by Ben on 01-23-2009 11:18 AM
Message 7 of 8
(3,732 Views)
Dear Ben
I think I don't get the second step. I pressed the "Cntrl"  button and drag my chart icon on the Ref made in first step but nothing happens.
I tried it with both char icon and its reference but it didn't make any difference.
Best regards
Afshin
Message 8 of 8
(3,696 Views)
