Timing column in the write to measurement file
Tried it.. It doesnt work.
Message 11 of 17
(864 Views)
when I tried the same it worked for me... can you share what exactly you modified in the code also share the output file that you get after this modification.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 12 of 17
(852 Views)
Please have a look at the following snapshots.
Message 13 of 17
(835 Views)
Here is the issue...!!
Spoiler
Either delete it OR double click and change the configuration as shown below...!!
Spoiler
Hope this is the solution...!!
Message 14 of 17
(829 Views)
Thanks, I suppose it did work.
But, the output(Time column) seems a bit wierd. I am rotating the encoder at around 50 rpm. And this is the output that I am getting. Shouldn't I be getting it in appropriate single digit seconds?
Your method did work. But do you know what is the problem? I am trying to troubleshoot my vi if it is working the way I need it to be.
I wish to have a pressure sensor triggered every z index pulse by the encoder. I am missing out alternate z index by acquiring 2000 samples (Encoder has 1000pulses per rev)
Message 15 of 17
(824 Views)
Any suggestions anyone.. Why is it giving so low values on time?
Message 16 of 17
(803 Views)
Thats low, as your loop rate is very high...!!
place some delay (Wait ms) in your upper loop and you'll see the value(s) of recorced timestamp is larger as compared to present value(s).
Forget to add earlier so now editing:
In your code if you keep any delay, you will get an overflow error from DAQmx, probably you may also want to edit both tasks and include:
I'm assuming your application doesn't bother about gathering all the samples... Smiley Very Happy
Message 17 of 17
(785 Views)
