 tj.diego
			tj.diego
			04-25-2010 12:34 PM
Hi to everyone,
i have some measurament file and when i elaborate it, i need timestamp with millisecond precision, but i can't read it in labview!!!
example of file:
Channels    4
Samples    5000    5000    5000    5000
Date    2010/04/23    2010/04/23    2010/04/23    2010/04/23
Time    12:40:59.828125    12:40:59.828125    12:40:59.828125    12:40:59.828125
X_Dimension    Time    Time    Time    Time
X0    3.3548640598213959E+9    3.3548640598213959E+9    3.3548640598213959E+9    3.3548640598213959E+9
Delta_X    2.000000E-7    2.000000E-7    2.000000E-7    2.000000E-7
***End_of_Header***
in labview i can read till second value not more!!! why?
 RavensFan
			RavensFan
			04-25-2010 12:38 PM
Windows timer doesn't really have the resolution down to the millisecond level.
Generally, the best you can get is about 16 msec.
04-25-2010 12:42 PM
for me is enough be able to read this value "12:40:59.828125" from the lvm file!!!
how can i do it?
 RavensFan
			RavensFan
			04-25-2010 01:13 PM
04-25-2010 01:37 PM
 James@Home
			James@Home
			04-25-2010 02:39 PM
Change the setup of your timestamp indicator.
Right-click, select Display Format
Change Type to Floating Point
Change Precision Type to Digits of Precision
That should be all you need to do to display fractional seconds.
04-25-2010 02:52 PM
i find the problem is in the tab "display format" there isn't an option with ms, see the image, so, is there another method to get this information?
 James@Home
			James@Home
			04-25-2010 03:03 PM - edited 04-25-2010 03:03 PM
Your "timestamp", not the "Timestamp" indicator.
Code can get confusing when you don't use meaningful and unique names.
04-25-2010 03:11 PM
 James@Home
			James@Home
			04-25-2010 03:20 PM
You didn't post your file, so I have no idea what resolution your data contains.
I was only looking at your coding, but you are likely correct.
Have you looked at the data to see if it has millisecond values?
That will be visible in your "Timestamp" indicator, you can adjust the properties.
You certainly cannot have resolution better than what is in the saved data file.
