Timer Interrupt.
Hello.
I want to simulate a timer interrupt. For this purpose I have two parallel while loops.
The first one has an event structure.
The second one has an "Elapsed Time" vi.
I am feeding the "Time has elapsed" output of the "Elapsed Time' vi in the events that trigger the event structure but it does not seem to work.
Please see the attached vi.
Any suggestions?
Thank you very much.
Vasilis.
Message 1 of 13
(7,858 Views)
Hello Vakost,
The easiest way to do a timer you can interupt is to build a FGV. You can also use a producer / consumer loop with queues.
BR
Vincent
Message 2 of 13
(7,845 Views)
Hello.
So, the reason that this vi is not working is because the Time has elapsed is not a global variable and it cannot feed the event structure?
I don't exactly understand, I am confused :(.
Vasileios.
Message 3 of 13
(7,822 Views)
Accepted by topic author vakost
Hi Vasileios,
no, ElapsedTime is no "global variable".
It's a VI - and it acts local in each instance you place on the BD! (That's called reentrancy in LabVIEW.)
Message 4 of 13
(7,814 Views)
Where can I found the "Create Timer Interrupt VI" on the Labview palette?
http://zone.ni.com/reference/en-XX/help/373925B-01/myrioreference/myrioref_create_timer_irq/#Input1
Hamid
Message 5 of 13
(7,377 Views)
Hi Hamid,
as can be seen on the page you linked to this function is part of the myRIO toolkit:
Message 6 of 13
(7,373 Views)
Thank you GerdW,
If I can call a VI by PC timer interrupt then it should be very accurate timming. I've already used the PC timer interrupt in the C programing to do a task every 1ms, but I'm not sure that VI can do that? Also, I couldn't find  the "Create Timer Interrupt VI" on the Labview palette. I installed the Rio toolkit too. It's on the help file, but once I click on the find it on the palette then it pops up an error.
Message 7 of 13
(7,371 Views)
Hi Hamid,
Generic answer: Use a timed while loop…
Detailed answer: on a Windows PC the OS/taskmanager is determining, which program will currently run and for how long it will run. You will not get an accurate 1ms execution order in your VI. Use a simple while loop with a 1ms wait in it…
Some functions are filtered according to the target they can run on.
Examples:
- On FPGA many functions from standard palettes are missing.
- You can use Watchdog functions on RIO targets, but not on Windows PC.
I guess this InterruptTimer is also very platform-specific and only available on your myRIO.
Btw. WHICH error do you get?
Message 8 of 13
(7,368 Views)
Thank you GerdW, I got it.
Message 9 of 13
(7,348 Views)
I could make my GUI to be almost real-time. It's sending the messages every 20ms and very rarely every 21 ms. This webpage could help me:
https://www.winemantech.com/blog/the-ui-thread-root-loop-and-labview-what-you-need-to-know/
Also, I used a "Timed Loop" instead of while loop for sending the periodic message to the interface( with setting of high priority and 1kHz absolutetime and dt=0.0002 or 0 )
Also, calling the dlls should be set on "Run in any thread"
Message 10 of 13
(7,316 Views)
