Timeout influence at Create Network Stream Endpoint
There's one question about Networks Streams, that is unclear for me. How exactly does timeout value affect endpoint creation?
The question is not that silly as it seems. Now I have one program with input and output NW stream, running on PC1, and the second one w/ the same streams, running on PC2. If I set timeout to 150 ms or less, the connection between reader and writer in some cases doesn't set up at all. I checked it out on two PCs with Windows 7 64-bit + LV 2016 64-bit and on two PCs with Windows 7 64-bit + LV 2016 64-bit and Windows XP 32-bit + LV 2011 32-bit. In the latter case the connection was established only one way - from XP with LV11 to 7 with LV16. But when I set timeout to 160 ms or above, everything starts to work OK. The init loop on master side is pretty simple:
NW stream init on Master side
The slave's loop is almost the same - it just has url input wired in the form "//IP-address/endpoint name". On both sides the writer endpoint is connecting to reader endpoint with its IP-address.
According to the docs on the subject I have these things done:
- NI PSP Service Locator (lkads.exe) and LabVIEW are both added to Windows firewall exceptions;
- Windows firewall service is switched off and disabled completely;
- No 3rd party firewalls or AV on the machines;
- All networks on W7 are set to "Home";
- Pings go fine between both PCs;
- Shared folders work just fine;
- When trying to create reader/writer endpoints on both sides I can see active incoming / outgoing packet exchange in network adapter's parameters (the same is shown in tools like TCPView).
So, what's the reason for timeout to be higher than 150 ms? Why I cannot set it to 50-100 ms (as in my other loops)?
(4,053 Views)
Well, in my LabVIEW RT Application where I'm establishing 4 Network Streams between my PC Host and a Remote RT Target, I use a timeout of 15000 ms, with the proviso that if the Streams do not connect, they simply re-try.  I wouldn't think to quibble if it were two orders of magnitude faster ...  Note that, depending on what else is going on (and, I presume, one of your Endpoints is on a Windows OS, which is not so deterministic), a 10 msec difference (between 150 and 160 ms) is "in the noise" (so to speak).
(4,015 Views)
It could still be your network.  If there is a lot of congestion on the network, it will take longer to establish the connection (lost packets have to be resent, collisions, etc).
(4,015 Views)
Bob_Schor
Well, I'm using the same approach - if there's no success on establishing a connection, then the both endpoints try to connect again and again. But I'm also using Stop mechanism based on notifier: when my Stop button is pressed, the notifier is set to True and all the loops must be stopped and the whole app must be shut down. So, it is better to me when it works as fast as it can.
All my endpoints run on Windows. And that's really strange. I checked a dozen times - when the timeout is 153 ms (to be very precise), no connection is made at all. But when I add just 1 ms to the timeout, it suddenly starts to work!
I may forget about this issue for sure. But I feel like I'm interested in this deal and the details because I'm into LabVIEW for a while. So, it seems to me, it's somehow related to the way how Network Streams work. In TCPView I see a huge number of TCP ports being allocated when trying to connect (starting from 59110, according to this). As I know NI-PSP uses Logos engine, I tried setting these keys in Logos.ini (the article [article no longer available]):
[logos]
Global.DisableLogos=True
Global.DisableLogosXT=False
and these two (in LogosXT.ini):
[LogosXT]
LogosXT_PortBase = 59110
LogosXT_NumPortsToCheck = 100
It doesn't seem to affect the timing issues. I'm not sure how Logos exactly works internally though.
crossrulz
I think this is unlikely because I tried it with several local networks made of two dedicated Gigabit network adapters and not too long piece of 8-wired cable. There's no any other devices on the networks of those PCs, so no congestion.
(3,993 Views)
