Timed or button controlled while loop
Hi everyone,
I have developed a program using statemachine method to controlled the while Loop two ways i.e, Buttons or Time.The start and stop logic wíth time and Buttons are working fine.
The Problem is the button or time selection depends on the Switch Position before running the program. I want to select them while running the program.
Here, in the program I have set Buttons as Default selection. So, I am unable to select the time while running the Programm. As i want to create a executable file. It will start running asa I open the vi. User will be unable to select time Option.
Please help me to solve the Problem
Thanks a lot in advance
(3,346 Views)
Accepted by Avalanche_27
Hi Avalanche,
create a new state to give the user a chance to select the mode like wait for an OK button before the "Time/Button" control is read.
(Or change that "Initialize" state to automatically present a dialog to select the mode. This Dialog expressVI can be customized to do that!)
(3,329 Views)
Hi GerdW,
Thanks a lot for the solution I customized the dialog box. Its working.
(3,314 Views)
