Timed loop structure settings
Hi. I had use "timed loop structure" when I comunicate whith device via ModbusTCP protocol. I need maintaining original frequency of poll the device. Then i have one of two "mode" settings of timed loop structure:
1. Process missed periods, maintain original phase;
2. Discard missed periods, maintain original phase.
But, second variant is slower. Why is it? In this case it can drop frames and saving time!
In my case first variant is 6 ms long, second - 13 ms.
(3,051 Views)
Hi Forest,
why do you need a TWL for Modbus communication?
Why enforce strict timing for a communication bus with high timing jitter???
What about state machines here?
(3,005 Views)
1) will process all iterations, 2) will potentially dismiss iterations. So 2) will have less iterations, so less throughput.
If first iteration takes 7 ms (period of 6 ms), the second period is missed. 1) will execute the second period anyway, 2) will wait for the next multiple, that will be 5 ms later.
(3,001 Views)
