Timed Loop: "Frame Duration" problem
Hi
I am practicing with "timed loop" block. In a simple vi with a timed while loop with 2 frames, I want to check each frame run time.
I used an indicator for frame duration output of each loop frames. But I didn't get any out on them, just 0 it returned.
Would you please guide me on this issue?
Many thanks
(4,315 Views)
The Frame Duration is how long it took the code in the previous frame to run, not including the waiting for the time to wait before starting the next frame.  See this variation.
(4,307 Views)
Yes, you are right. So which frame output nodes will return me exact time spent for each frames? I want just to check precise timing of loop and frames.
(4,297 Views)
I think you are just going to have to subtract the Actual Start times to get what you want.
(4,265 Views)
