Time string writing extra zeroes to my text file
I am using the get time/data and format date/time string to write a running log of my while loop time while my program is running. The problem is the text file has the time  written in this format: 12:26:13 -0.000000, where did these zeroes come from and how do i remove them? If i hook up an indicator to the time strring output I do not see them only the time but there it is written once i open up the file.
(2,923 Views)
Accepted by labview12110
Assuming you are viewing the file in Excel, it will choose a format to display a date/time field (not necessarily the format you desire).  If you open the file in a text editor, it will probably be displayed as you told it to be displayed.
aputman
(2,915 Views)
nevermind i totally missed that a tab and was adding my next string value to this one.
(2,910 Views)
What format string are you using?
aputman
(2,899 Views)
