Time-loop at 1 MHz
Ok,
I just followed the instruction of RavensFan who said that I make two loops, one for acquisition, the other for analysis and writting.
But I did as you said and it works now.
Each mesure will be done with a lapse time given by Number of samples / sampling frequency.
Anyway, I understand a little bit more what happen in LabView now and I have what I want.
So thank you very much, both of you.
Cheers.
Message 11 of 12
(942 Views)
Ravens recommended a producer/consumer architecture but that is not what you did with the two loops. That is a more sophisticated design and one you should learn.
Message 12 of 12
(938 Views)
