Time controlled Loop faster than 1ms
Bad news for the original poster, Steffen:  I don't think a USB-based board will work nearly as well for this stuff (perhaps hardly at all) as a PCI card.
I would suspect the same. The hardware timed Timed Loops appear to be clcoked by the interupt service routine and since USB can't assert PCI bus interupts...
Ben
Message 21 of 24
(1,192 Views)
Ben wrote:
" Bad news for the original poster, Steffen:  I don't think a USB-based board will work nearly as well for this stuff (perhaps hardly at all) as a PCI card."
Ditto.
Plus you need to learn the "tricks", which under "controlled" situation, you might get away with, but for precise timing, you'll need a better OS than windoze.
Has anyone experimented with Linux???
RayR
Message 22 of 24
(1,188 Views)
There was this post a while back where someone was asking for "change detection" on USB.
I searched the forums and read that some of the the M Series High Speed USB devices have support for edge change detection. This should be able to drive a timed loop, but the question would be "How fast will it go?"  Anyone out there with an M Series USB device (non bus powered) and a function generator that wants to perform a test?
Message Edited by Phillip Brooks on 12-14-2007 06:42 AM
Message 23 of 24
(1,166 Views)
I've done non-RT but deterministic, faster than 1KHz DAQ, non-National Instruments hardware with GaGe products.
I'm sure there are other manufacturers of similar boards. You will need an external trigger and a DAQ board capable of buss mastering. The scope board essentially takes over the bus during acquisition. With a sufficiently deep memory you get all the determinism you need. These boards are not cheap, but cheaper than an RT system. And you can write/develop/debug your code on your PC at your desk. Smiley Very Happy
PaulG.
Retired
Message 24 of 24
(1,155 Views)
