Third-party distribution kits
Is it possible to use a third-party installer authoring tool (for instance Install Shield) to deploy my own LabVIEW applications together with the Runtime Engine?
If so, what files should I copy?
Thank you!
(2,816 Views)
I use Installshield Express 3.03 to distribute my application and Runtime Engine. To install the
RTE, copy the entire directory, C:\Program Files\National Instruments\shared\... into the installer
where you normally add files. (This RTE directory is created when you install the RTE on your
computer.) InstallShield takes care of making all the proper registry entries.
"Giovanni" wrote in message
news:5065000000080000002A340000-1005954886000@exchange.ni.com...
> Thank you!
(2,816 Views)
