Thermotron 8800
GM Montevan, I have somewhat working, I have also tried to put a beep connection using call back function for beep, I want it to beep when it has not been able to establish connection or looses connection, I am sure I need to add some type of conditions to my wiring.  Can you look at my VI and give me some type of hints.?
Rulee
Message 31 of 40
(2,057 Views)
I can't help you with your .NET programming but I did make some changes to make it work...
See attached.
Message 32 of 40
(2,052 Views)
Montevan, I have LV 8.2.1 version and cant open it..
Rulee
Message 33 of 40
(2,050 Views)
Montevan, can you please send me a picture of the VI..
Thanks!
Rulee
Message 34 of 40
(2,049 Views)
Message 35 of 40
(2,044 Views)
Thanks Montevan, I cant still hear the beep from PC when it stops. Maybe it is the audio frequency or card in pc.
Rulee
Message 36 of 40
(2,040 Views)
I removed the .NET portion of the code because I did not understand it.  I just wanted to show what you need to get communcation going with our controller...
Message 37 of 40
(2,037 Views)
OK THANKS!
Rulee
Message 38 of 40
(2,031 Views)
Be sure to change the IP address back!
Message 39 of 40
(2,027 Views)
I hear the beep.
Message 40 of 40
(2,018 Views)
