Thermocamera
Hi! I'm new with Labview! Sorry! I want extract temperature data ( in form of a 2D array or matrix) from thermocamera images. I have the temperature map. I can choose the temperature appearance (light, rainbow, RGB colors) of the thermocamera and the temperature scale ( ex from 25°C to 200°C).
Can I do this with Labview? If yes how?
Many thanks!
(1,649 Views)
Do you have saved images on your computer, or are you trying to read directly from an instrument?
If the image is on your computer, can you attach one here?
Is thermocamera a brand/device name, or can you provide a make/model of your thermal camera?
(1,596 Views)
The thermcamera is a fluke 401 pro and I use the Fluke connect software to elaborate the images that I obtain directly from the instrument.
I attach an example of image I obtain. I would have a temperature map in terms of array in order to analyze the temperatture distributionscala.pngtermocamera.png
(1,537 Views)
Hi FFoglia,
what datatype/format do you get the image data?
  1. Do you get a PNG/JPG/BMP image with 24bit RGB values?
  2. Do you get an 8bit image with a colorscale?
Do you use an intensity graph to display the image data or do you use a picture indicator?
In case 1 you would need to read the color value and search for that color valu in your temperature/color scale to get the temperature.
In case 2 you can simply scale the U8 value into a temperature based on color scale min/max…
(1,530 Views)
