The sum of arrays of different size
how i can to sum multi arrays of different size.
hank you .
(3,937 Views)
Accepted by Sarah_LAB
Hi Sarah,
simple solution: make them the same length…
Other solution:
Determine the largest array size.
Use a (FOR) loop running for this number of iterations.
Index the arrays inside the loop and add the element values…
(3,936 Views)
