The specified Python function could not be found in the specified module.
Got this error after the program run , what is ReadImage function ? why it couldn't be found while the program already run successfully ?
file as attached below
(3,584 Views)
it is supposed to be a user defined funtion within the python script you are calling
(3,575 Views)
Accepted by PULSE.Wannabe
goes like this
def function():
 x = ...
 return x
an easy example of a user defjnied function is shown in
C:\Program Files\National Instruments\LabVIEW 2020\examples\Connectivity\Python\support
Spoiler
import math
# EuclideanDistance(point1, point2) is called from PythonNode_ComputeEuclideanDistance.vi.
# LabVIEW passes the two point clusters as python tuples. The elements of the tuples can
# be accessed by indexing the tuple. The return value of the function is a double.
def EuclideanDistance(point1, point2😞
    xDiff = point1[0] - point2[0];
    yDiff = point1[1] - point2[1];
    return math.sqrt(xDiff*xDiff + yDiff*yDiff);
(3,521 Views)
thanks so much , I'm quite a beginner in python, met "return" few times but didn't know what it does
(3,506 Views)
by the way, do you know how to take number/ data out from the python from the labview? I want to take data from python then process it in labview
(3,505 Views)
Click on Help >> Find Examples... and search for "Python", you will find several examples.
(3,501 Views)
