The quickest way to search a 2D array for matching
Please find the VI attached, full credit to altenbach from his previous reply on Re: How to match data in different array columns
I will be manipulating a 1000 row array with two columns for matching. I was just wondering if there was a quicker way to achieve this than the design below. I was just considering latency, especially with the fact that large batch tests will be run in the future.
I had an idea that a case structure could also be used to identify the user input, but wasn't quite sure if latency would have any impact.  LookUpTable.PNG
Open to any ideas you may have.
Many Thanks & have a nice weekend!
Message 1 of 20
(9,336 Views)
No VI is attached.
aputman
Message 2 of 20
(9,333 Views)
Sure, VI now attached
Message 3 of 20
(9,297 Views)
Here's mine. I don't know how fast it is. I believe you can make a nice lookup table using variant attributes, but this is just easy...
Message 4 of 20
(9,284 Views)
Accepted by neunited
Yes, this is clearly a prime case for a variant attribute table based LUT. Now you don't even need a case structure. 😄
You would place the parts on the left into a subVI and create a new variant whenever you want to load a new LUT from file. Note that a variant based LUT is very efficient.
(EDIT 04-18-2022: corrected attachment to remove extraneous \n default value in string control)
Message 5 of 20
(9,268 Views)
Altenbach Thank you,
I ran the simulation a few times comparing the original vs. your LUT and noticed a substantial improvement in the latency.
Thank you for sharing your knowledge.
Many Thanks
Message 6 of 20
(9,197 Views)
For large tables, the difference will be dramatic. "Search array" needs to inspect about half the elements on average before a match is found (best case 1, worst case N elements, if not found also N elements).
If you know that the array is sorted, you could substitute a binary search where it is sufficient to inspect only log2(N) elements before getting the result. (search array could add this option in the future, that's why I made this idea, but you could also roll your own of course). Imagine if you had a LUT with about 64k entries. Search needs to inspect between 1 and 64k entries (average about 32k, but every single element whenever the search fails) while a binary search on 64k elements only needs to look at 16 elements in the worst case, i.e. many orders of magnitude less.
Variant attributes use a highly efficient internal data structure (red black tree) that also performs in log2(N). I use it for example to cache the results of certain expensive calculations to avoid recalculations and it performs great (details).
Message 7 of 20
(9,193 Views)
Dude, that was awesome.  🙂
Bill
CLD
(Mid-Level minion.)
Message 8 of 20
(9,142 Views)
hello every one, could you please give me a VI file for better understanding. Thanks
Message 9 of 20
(7,940 Views)
Hi sam,
see the attachment in message #5…
(When you want something else you should ask more specific!)
Message 10 of 20
(7,936 Views)
