The file path and directory about the .exe file created in LabView, who knows?
I have a project, in the project, VIs and documents(.doc,.txt,.tdms,etc.) in different directories, and when the project run in the labView, it can find the directories and files, but when I created .exe file, I found the directories had changed and I didn't know the directory structure in the file, anyone know it?
Thanks for any reply!
YangAfreet
(2,858 Views)
I'm not sure what you mean by the directories had changed.  Is your problem related to the relative path of a VI in an executable is different than its path in the development environment?  Look at this thread.
(2,852 Views)
