The ID Query failed (-1074003951) in Keysight MSOS804A
I'm having the exact same problem! Has anyone found a decent solution?
Message 11 of 18
(1,800 Views)
Hello
I am having "The ID Query failed (-1074003951)" issue with LMG95 power analyser, since i got new developer PC.
Old labview version: Labview 2016
New labview version: Labview 2016 f7
Can this issue be caused by the difference of labview versions? The project is the same as before.
Kind regards,
Balázs
Message 12 of 18
(1,430 Views)
@LTBALAZS wrote:
Hello
Kind regards,
Balázs
After seeing your post and reviewing the original post, the issue the OP was having is just as they said, the capital letters returned by the ID string were causing the ID to fail.  I extracted out the part of the driver where the match first string comparison is done and changed the prefix array to all caps and the match worked.
So basically, you need to double check in the initialize VI, first of all, if your specific device is listed (compatible) and secondly, make sure that the value returned by the ID matches the value in the prefix array (letter case, spacing, etc).  This assumes the drivers were created by NI and follow a similar format as the drivers above.
aputman
Message 13 of 18
(1,410 Views)
@aputman wrote:
@LTBALAZS wrote:
Hello
Kind regards,
Balázs
I find many, many HP/Agilent/Keysight drivers suffer from this issue.  I even found a case where new firmware reported a string different enough not to find a match with the strings they were using in the driver!
Bill
CLD
(Mid-Level minion.)
Message 14 of 18
(1,393 Views)
And they are usually NI certified.  🙄
aputman
Message 15 of 18
(1,391 Views)
NI Certified does not guarantee the driver will work, it is the driver developer's responsibility
Certification just ensures compliance with the guidelines, so, you cannot quote "NI" on anything unless it is an "NI Driver"
Here is how you can get anything certified to be on IDNET - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015CfoSAE&l=en-US
Santhosh
Soliton Technologies
Message 16 of 18
(1,370 Views)
Yeah, I found that out too. "NI Certified" doesn't mean you think it means 😉
Step 6.1 is interesting: "Make sure to include the instrument manuals with the instrument driver submission."
Why does NI need the manuals if they are not checking any of the command are correct? All NI is doing is running some VIA against the code (or so I assume).
Message 17 of 18
(1,350 Views)
It was because of wrong baud rate! Thank to everyone!
Message 18 of 18
(1,328 Views)
