There is text a file with three columns of numbers (type 1.234), between columns the empty space can be created by means of tabulation and-or a blank. Besides in the end of a file there can be empty lines from табуляций and-or blanks. It is necessary these given to transform in numerical array for the subsequent processing. In my example LabView incorrectly translates numbers and perceives empty lines as zero number (in Control Panel format numbers for Russia - 123 456 789,00).
it's not incorrect to convert empty lines to empty array elements...
You should remove empty lines before the conversion or remove empty rows/columns in the array after conversion! In newer versions of LabView you will find a function to "trim whitespaces". I have attached a down-converted version
Best regards, GerdW
