‎06-17-2020 02:02 PM
Would somebody happen to have a simple example VI for the following:
Text file import into Excel. Anything reasonably close would be appreciated thank you.
‎06-17-2020 02:14 PM
Hi chrlum,
Read the text file using ReadTextFile in LabVIEW. Then use RGT functions to send to text data to Excel.
LabVIEW comes with RGT example VIs…
‎06-17-2020 02:38 PM - edited ‎06-17-2020 02:39 PM
This is hardly a LabVIEW problem...
‎06-17-2020 03:00 PM
I'm kind of a newbie..RGT?
Could you direct me to that example?
‎06-17-2020 03:41 PM
RGT = Report Generation Toolkit
‎06-17-2020 04:49 PM
Yes that's exactly what I needed thanks again..
‎06-18-2020 11:21 AM
I'm having a little trouble with "easy text report VI"
under report generation.
I'm in version 2015..
Does anybody have or can direct me to an example to run this VI using Excel report type?
‎06-18-2020 11:39 AM
I don't have 2015 installed to check, but if I open the Example Finder ("Help > Find Examples..." on the toolbar in LabVIEW) and then go to the search tab (top left) and search for "report generation excel" I get a whole collection of examples.
Admittedly the first one is for an HTML report, but reading from the second entry works fine 😉
‎06-18-2020 01:33 PM
