Text file and string indicator
Hello Everyone,
I have a basic question but I'm just learning :(, how could I read a text file with three words (Sample 1, Sample2, Sample3) and put them in a string indicator?
(2,560 Views)
Check the function Read spreadsheet string.vi
RKO
(2,548 Views)
Accepted by Mocte117
A single indicator or multiple indicators?
For a single indicator, just read the file and write directly to the indicator.
For multiple indicators, you can probably use Spreadsheet String To Array to parse the string and then Index Array to get the 3 values to write to their indicators.
(2,542 Views)
Use "Read spreadsheet string.vi" and then all of them will in the array.
please set this as ANSWER or KUDO this post, if it help you.
(2,510 Views)
I was trying to develop the solution you gave me but I ran into problems. Could you help me?
This is The Vi that I tried to do:
(2,409 Views)
Just change the read function to output DBLs, then index from it.
(2,398 Views)
 Resolved:
(2,363 Views)
