Text File
Spreadsheet string to Array doesn't care about the quotes.  Make sure you use a comma as the delimiter.
But every element in your first column will start with a quote, and every element in the last column will end with a quote.  What you can do is use some string subset functions to remove the quotes from those elements after the fact.
If you don't expect a legitimate quote to ever be in the file, then you could search and replace all quotes with nothing before you turn it into an array.
Message 11 of 11
(516 Views)
