Testing product with USB Port
Hi adambe,
Looks like this solution is working. I will give it a thorough testing, and if this works out great, you are on your way of getting a Kudos.
Thanks for the help.
I found this document on FTDI website after going through your post. It explains a lot of things.
http://www.ftdichip.com/Support/Documents/AppNotes/AN_107_AdvancedDriverOptions_AN_000073.pdf
Kind Regards.
Message 11 of 13
(847 Views)
Hi SnowMule,
Thanks for your help. We are already using the Devcon.
Our main issue is the device detection time by Windows.
Kind Regards.
Message 12 of 13
(825 Views)
It appears that you have some hardware and software expertise at the microcontroller level.
Would it be feasible to design your own USB isolator/repeater?  It would consist of a USB connection to the Windows computer (which never gets disconnected) a microcontroller to manage the USB connection and then a second USB port to connect to your device under test, also managed by the microcontroller.  I have not done this but it seems like a possible way to fool Windows into thinking that you have not changed devices.
Lynn
Message 13 of 13
(801 Views)
