Temporary directory for LabVIEW application builder
I have LabVIEW 2020 professional version installed on my computer. I have used application builder to build multiple applications without any issue until recently (probably after some Windows updates? but I am not sure). Right now, when I try to build even the same application that used to work before, I am getting "Error copying files...". Inside this long error message, I could see something like "Destination: C:\tNIAB\..." followed by
"Copy in Copy From Folder To Folder.vi->Librarian Copy.vi->AB_Destination.lvclass:Copy_File.vi->AB_Source.lvclass:Copy_SourceItem.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller<APPEND>
C:\tNIAB\<filename_to_copy>"
When I check the detailed error I could see this following,
Click the link below to visit the Application Builder support page. Use the following information as a reference:
Error 6 occurred at AB_Destination.lvclass:Copy_File.vi -> AB_Source.lvclass:Copy_SourceItem.vi
Possible reason(s):
LabVIEW: (Hex 0x6) Generic file I/O error.
I/O operation aborted."
I have tried to repair the whole LabVIEW from NI package manager but see no difference after that.
Does anyone know how to get this fixed?
Thanks.
(2,038 Views)
Can you share a slimmed-down version of this project? Also, can you try to build a new application with a new project and just a blank VI as the main and see if it still fails?
Sometimes application builder throws that error 6 if the folder where you are building is open, so just make sure windows explorer or any other applications that might be using that folder are completely closed?
(1,948 Views)
R-click the build action in the project and select "Clear" or something similar and make sure no files from that structure is open in another program and it'll lock them.
Qestit Systems
Certified-LabVIEW-Developer
(1,941 Views)
Accepted by stevensung
Thank you for all replies to my post.
After some troubleshooting, I realized there were some dependency subVIs broken. These subVIs are part of the .NET calls and were not ringing the bells when I tested the main VI in the development mode for some reasons. After fixing them all, I retried to build the application and this time it worked.
So I will close out this topic.
(1,936 Views)
