Telecommunications Parametric Testing.vi
In LabVIEW2010 example subdirectory for database is a program "Telecommunications Parametric Testing.vi".  As soon as I open it, it begins to run.  When I click the "Quit" button, it disappears from the screen.  I would like to see its block diagram.  Is this possible with this particular example?
(4,165 Views)
Accepted by mysticfree
Hit Ctrl - .   (Control - Period).  That aborts the VI from running and leaves it in edit mode.
(4,160 Views)
To view / edit VIs that are set to run at launch just drag the vi onto another block diagram.
You will then be able to open the vi.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(4,152 Views)
What part are you interested in? Long before it was a 'database' example, I was given the T1 generation/mask test code by an NI Engineer.
(4,144 Views)
Perfect!  Thanks!
(4,125 Views)
Hello Dennis,
The short version is that I'm on a quest to figure how to convert my tester programs from using Access database files to using MS SQL.  I've been told that MS SQL is a better route to go than Access.  In my search to make this happen, I found the examples/database and then the fun began ...
(4,122 Views)
