Tektronix 210 "channel" command
Hi all,
I am now developing the control program of Tektronix
210 oscilloscope. However, I cant find the control command " channel" ( as I want to control the use of chanel 1/2, Can anyone help me to solve the problem?
thanks a lot
(2,534 Views)
CowCow,
If you are using the tktds2x0 IVI driver from our websote, then you need only use the Enable Channel function provided by the driver.
The instrument's command is
:SELect: { OFF | ON | }
- CH1, CH2, MATH, REFA, REFB
- 0 = OFF, non-zero = ON
--Bankim
Bankim Tejani
(2,534 Views)
