TekScope Screen Save Hardcopy to PC
Hello Supporters,
             I'm using 5k series Tekscope and trying to save hardcopy of Tekscope screen to PC. I ran the VI, where Tektronix posted their forum and it makes it to the visa read vi and then throws an error with code -1073807339. It looks to be a timeout error where nothing is being sent back. When I ran the VI scope is generating a capture png file by itself, but LabVIEW thrown timeout error.
            Even though I was tried many SCPI commands where I found in forum, but I couldn't achieve the result yet (Every commands gives me rapid timeout error).
            Is anybody have a solution for this?
            As shown below image codes are found it in Tektronix forum(It's not working);
2K, 3K, 4K series2K, 3K, 4K series
5K & Up series5K & Up series
(4,219 Views)
I assume you have turned on tracing and observed your code execute. I will also assume that the error occurs at the VISA.READ command.
Have you read the manual for the hardcopy command? I would assume it would take some time to write to disk, so I would add a delay between the ":HARDCopy STARt;" cmd and the ":READFILE" cmd.
Also the default VISA timeout is 2 seconds, depending on how large of a file you are transferring, it might be running into that limit. Try adjusting the timeout. (VISA Pallet -> Advanced -> VISA Property)
(4,194 Views)
You should really attach your code not post picture of code.  It makes it easier to get help.
In picture 1 the timeout is only 5000ms, why not set it to something much, much longer?  300,000ms?  Its a timeout (maximum wait time before instrument throws an error), so setting it to a very long time shouldn't slow things down.
In picture #2 there is no timeout set, so its likely 1000ms (1s), so why not implement the timeout from image #1 in image #2 and set it to a longer time and see if things work?
Craig
(4,191 Views)
Here is my code! Rescue from timeout(Read VISA) error.
(4,173 Views)
Accepted by topic author SabariSaravanan.M
Damn! I found solution by myself, here is that.
(4,154 Views)
