Target-scoped FIFOs/ missing methods error
In my project, there are two FPGA vi's and 4 pairs (read and write) of target-scoped FIFOs that are used to pass data between the two vi's.
One FPGA vi (named rs232.vi)  writes data that it obtains from an RS232 port to READ FIFOs; it also reads data from WRITE FIFOs and passes it to  ports.
The second FPGA vi (named griffin commands.vi) writes data to WRITE FIFOs and reads data from READ FIFOs. There are no other vi's in the project.
When I try to run either of the vi's, I get an error about missing methods for FIFOs. For example, when I run rs232.vi, I get an error that Read FIFOs need to have the read method (see image named rs232 side) and that Write FIFOs need to have the write metod presend on the block diagram in that vi. However, these "missing" methods are present in the second FPGA (as I described above). The same type of an error appears when I run the second.vi.
Why can't the compiler see that I have all  methods; however, they are in 2 separate vi's? How can I avoid this error?
(5,320 Views)
Can this be due to problems in the hierarchy ?
(5,319 Views)
Are both of these VIs called from the same top-level VI? If not, that error makes sense, since you can run only one top-level VI on the FPGA at a time.
(5,301 Views)
Why can't one of the vi's be the top level vi?
(5,291 Views)
Accepted by SophieJS
That would be fine too, so long as one of them calls the other. I didn't see that in your screenshot, though.
(5,285 Views)
