‎07-17-2011 11:17 PM
By asynch, do you mean Serial/RS-232? The only advantage is that it is cheaper. I believe you would have to make some simple mods to add serial support so that will offset some of the cost savings.
‎07-18-2011 11:09 AM - edited ‎07-18-2011 11:10 AM
Yes I was referring to the Serial/RS-232 interface. Is the performance the same between RS-232 and GPIB? Are there any known issues with one or the other?
‎07-18-2011 11:56 AM
No, of course the performance is not the same. You should be familiar with the basics of both types of communication. A serial connection might have 115k rate and a standard 488.2 connection is 1MB.
‎10-24-2012 01:16 PM
Have you tried to add a CTL + C (^C) string to the initial command?
I found that the FireBERD 6000 does not communicate over RS232 until the ^C is entered. Even using HyperTerminal.
I found however that I am unable to get results from the results command via LabVIEW VISA but I can get results from HyperTerminal. Command; RESULTS? DATE returns nothing from the VISA Read but does over HyperTerminal.
Anyone find a solution to get results over Serail RS232?
