Take time between two max values
Use fewer local variables. You have a couple of places where the local variable is read before the terminal is written. That is a "stale" value.
You are only taking one sample at a time, so the output type of "array" isn't valid. Either read more samples, or use a scalar.
This isn't very clean, but it might be closer to what you're looking for:
Message 11 of 62
(1,404 Views)
Hi Uday, I'm use the version 10.
What you modify in the program?
Because the problem is the same...
There is no substract between the actual number from last number
in the 17,990 - 17,910 =  0,08 or 18,010 - 18,000 = 0,010
Now the substract is from the actual number from the first number...and this is wrong...
thanks for the help...I no see any solution... :((
Message 12 of 62
(1,389 Views)
Hi Todd,
This I tried to do in Labview and it doesn't work...because I need to use Analog 1D DBL 1chan Nsamples.
I don't know if I'm explained good about what I'm looking for....
I have a voltage and time...this voltage has diferent peaks at max value.
I want to calculate de tame between every peak that I have...for example see in the picture.
thanks a lot people for the help...is very importan for me!!
Message 13 of 62
(1,381 Views)
You have stated the problem very clearly. Why nSamples? In the VI I downloaded, you had the sample count set to one - which will return an array with only one value per channel.
Message 14 of 62
(1,360 Views)
Because if you put Nsamples You can use the Array Max and Min and this help to know wich is the max value every moment....
In the program you draw this vlaue you put a control...this depends on the measurement....
You see the picture called "time"...is it possible to do this?
thanks for the help...my english is bad and sometimes Is it difficult for me to understand...
Jocuma.
Message 15 of 62
(1,352 Views)
I think I understand.
If you take the maximum value of an array that only has one value - you get that value.
max ( [2, 5, 3] ) = 5
max ( [-2] ) = -2
Message 16 of 62
(1,341 Views)
Yes...Because I only want the Voltage Peaks....and when it appears this peaks...there is a time between peak1 to peak2
this time Is what I want to save in a table...see this picture.. :S
thanks! 🙂
Message 17 of 62
(1,338 Views)
Hi Uday, Here you have the samples that I take...
Message 18 of 62
(1,329 Views)
In the samples you sent, there are no peaks forming.Till 1 sec, it is 7.xxx and after that it is 4.xxx. It is never high then. that is the reason you are not getting any peaks. Am i right.?Please check the data.
uday
Message 19 of 62
(1,315 Views)
Yes I get the peaks beacuase 4.xxx is the constant voltage and when it's 7.xxx is the peak that I have...
you understand me?
Always there is a voltatge 4.xxx and when there is 7xxx is the peak that I have.
thanks Uday,
Message 20 of 62
(1,313 Views)
