Tag Data design for parallel read/write
@OneOfTheDans wrote:
wiebe@CARYA wrote:
Add normal globals to that list. Read and Write are 'split' by default, so you always get (the risk of) race conditions. If you wrap the global access in a VI, you're back to blocking...
If 1 global/tag or 1 global/instrument, I still have the issue of needing to pre-define all my instruments at edit time (no dynamic loading). I think Shared Variables are essentially the same as globals. Either could be made dynamic, like the Global: Map( tag: value ), but it's so race-prone it's basically guaranteed to squash data from any writes.
Your comments reminded me that Notifiers exist and could maybe be used here... I wonder how bad the overhead is for LabVIEW to maintain a few hundred Notifiers?
If you really need global data, I'd at least try to minimize the scope.
I wouldn't give instruments global data, but make instruments focus on doing their thing (single responsibility). The data coming from the (dynamically started) instruments can be collected, either in a global data bus, DVR, queue, user event, etc..
Notifiers are too complex for my taste. I know they're potent, and people use them. I'm pretty sure they are optimized very well, like queues.
Message 11 of 16
(912 Views)
wiebe@CARYA wrote:
That's new to me. How?
I think that happened in 2017. Sure its a right click on the DVR node in the IPE structure.
Message 12 of 16
(909 Views)
Mark As Modifier? That doesn't avoid blocking...
Message 13 of 16
(900 Views)
DVRs can allow parallel read-only access.
Still, it is not an advantage over FGV (nor globals). When  reading data from a FGV it won't block execution, as the read would be very fast..
I actually ran into a corner-case exception to this many years ago.
We had an RT system that used an FGV as a shared "tag engine" of sorts (we referred to it as "data soup").   Most modules ran in sequence, but we had a main time-critical process that ran in parallel to the sequencer.
We noticed that our 1 kHz time-critical loop would normally execute in a small fraction of a msec, but would occasionally spike up to be slightly over 2 msec in an erratic pattern.
It turned out that one of RT's rules about "priority inversion" was the root cause.  When the time-critical loop was ready to execute an FGV read but some other lower-priority process was in the midst of using it, the priority inversion avoidance algorithm would kick in to bump the low-priority process and give priority to the time-critical process first.
   So far so good, *except* that the mechanism for performing this act took 2 msec each time it was thought to be needed.  Here's a prior post with a little more info (and the solution we settled on).
Dunno if any such issue is still in place under newer RT OS'es.
-Kevin P
Message 14 of 16
(895 Views)
That's the left node.  You have to do it on the right node.
When you do that, it changes from a pen to a bunch of stacked glasses:
Message 15 of 16
(883 Views)
Pointless comment:  seems like an odd choice to put it only on the output-side node.   Makes more sense to declare it as read-only on its way *into* the IPE structure...
-Kevin P
Message 16 of 16
(874 Views)
