Table row switch
Hi there,
I'm working with a system that has a log-file.
A small part of the file is added as attachment.
What I want to do is to scan the file and put the latest date (30-03-2010) at the top.
So the dates have to go from newest to oldest date.
Then I want to put the data into a string and put it in a table.
How can I do this in Labview?
Message 1 of 9
(3,916 Views)
Hi Cheese11,
you can use the "Read From Spreadsheet File.vi" to get your data into a table. With "Index Array", "Sort" and "Reverse" can you modifiy it for your needs.
Mike
Message 2 of 9
(3,909 Views)
Hey Mike,
I'm doing that to put it in a table.
But when I use the "Reverse"-block, the columns will get reversed, but not the rows.
And with "Sort" it is the problem that I need a 1D Array.
In my file you can see dat the Array consists out of more columns.
So are there any more solutions or do you mean something else?
Greetz
Message 3 of 9
(3,904 Views)
Hi Cheese11,
see the attached image.
Mike
Message 4 of 9
(3,901 Views)
Mike,
What is the name of that 2 ABC-blocks, can't find them.
Message 5 of 9
(3,897 Views)
Bundle and Unbundle
You will find them here : Functions palette >>  Cluster, Class & Variant
Message 6 of 9
(3,892 Views)
Mike,
I'm very sorry, but now I can't find the 2nd block, the block after the "Read Spreadsheet String" block.
Greets
Message 7 of 9
(3,888 Views)
Accepted by topic author Cheese11
Hi Cheese11,
from left to right.
"Read From Spreadsheet File"
"Index Array"
"For Loop" with "bundle"
"Sort 1D Array"
"Reverse Array"
"For Loop" with "unbundle"
"Array of String indicator"
Mike
Message Edited by MikeS81 on 03-30-2010 10:57 AM
Message 8 of 9
(3,886 Views)
Hey Mike,
Thanks for your help!!!
The vi is doing what I want.
Greetz
Message 9 of 9
(3,878 Views)
