Table display sequence
How to make change to the vi to let the column of value and result update data by row. The current vi update everything by row including the test, and both limits. So how to make the column of test and limits remains static, only let ' value and result' update by row.
(2,128 Views)
Just initialize an array at the final size with empty strings, fill the static entries, then replace elements as you go. Note that you need to replace with a single-row 2D array if you want to replace only a partial row.
(can you explain why you write to the table value property instead of the terminal? Makes no sense)
Here's a simple rewrite. Make sure you understand the purpose of every element.
(2,087 Views)
Solved
(2,037 Views)
